Tuckab
May 18, 2018Follower
Netgear C3700
My Netgear is working but connection speed is very slow in event logs it says critical 3 T3 timeout it worked perfectly fine now it doesn’t don’t know what happened
DarrenM
May 21, 2018Sr. NETGEAR Moderator
This is typically a ISP issue you may need to contact your ISP and have them investigate your cable lines.
DarrenM
