biggermac
Nov 27, 2019Follower
netgear c3700/n600 inconsistent latency
Hi there! I have had really inconsistent latency the past month and, after contacting my ISP's [Cox] support several times to no prevail, they have instructed me to reach to my modem's support which ...
Dec 02, 2019Guru - Experienced User
Are you testing with a wired PC?
Ensure there are not coax cable line splitters in between the modem and ISP service box.
Ensure the ISP has checked the signal and quality up to the modem after removing any line splitters.
Ensure your using good quality RG6 coax cabling.
Might need to try a different model modem.
