Espinoza109
Dec 22, 2023Aspirant
NETGEAR C6220 Modem not working wifi issue
This modem as finaly been registered and setup, however, i need to change the default name and password. routerlogin.net or whatever it is has not worked or allowed me to login with the default admin...
Dec 22, 2023Guru - Experienced User
What happens when you try to log in?
the password is required to be changed when you set it up. Did you do that?
- Espinoza109Dec 22, 2023AspirantI never changed a thing when It was first setup. It is still the original router name and password listed on the sticker that’s on top of the router.
- Espinoza109Dec 22, 2023AspirantIt does not let me login on router login.net or whatever that page is…
- FURRYe38Dec 23, 2023Guru - Experienced User
Try a factory reset on the modem and set up from scratch with a wired PC and web browser.
