Espinoza109
Dec 22, 2023Aspirant
NETGEAR C6220 Modem not working wifi issue
This modem as finaly been registered and setup, however, i need to change the default name and password. routerlogin.net or whatever it is has not worked or allowed me to login with the default admin...
Dec 22, 2023Guru - Experienced User
What happens when you try to log in?
the password is required to be changed when you set it up. Did you do that?
Espinoza109
It does not let me login on router login.net or whatever that page is…
- FURRYe38Dec 23, 2023Guru - Experienced User
Try a factory reset on the modem and set up from scratch with a wired PC and web browser.
