RyanMinor121
Sep 13, 2019Follower
Netgear C6220 router has slow speeds
It seems that lately, the speeds I am able to get through my Netgear C6220 router have been relatively slow (30mbps). When I reboot the router the router, I don't see any increase in speeds however wh...
Sep 13, 2019Guru - Experienced User
You're posting in the wrong forum for this device. Here's the correct one.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
When you redo this in the correct forum (as there's better help there) try to include these details.
Who's your isp?
How are you testing speeds? Aka device used, wifi/ethernet, website used
Its always recommended for speedtesting to be done over a hardwired connection as wireless can have a multitude of other issues.
A screen shot of your connections page (upload and download) and your logs. These help figure out if your connection coming into the house is good.
make sure to remove any splitters, amplifiers, elbows, and to check your cables for poor connections, bends, water damage. Poor signal can impact speeds greatly and these are some of the most common reasons for poor signal.
