b3045
Apr 15, 2020Follower
Netgear c6220 wifi issue
I recently moved to new place, i used to have comcast cable internet, i was using netgear c6220 model for wifi. Now i switched to Spectrum that is the only internet available. Anyway i received modem ...
Apr 16, 2020Guru - Experienced User
After pressing the reset button on the back of the modem for 15 seconds then release. Do you no see the default SSID name coming from the modem at all? If it doesn't appear, the modem should be replaced.
