b3045
Apr 15, 2020Follower
Netgear c6220 wifi issue
I recently moved to new place, i used to have comcast cable internet, i was using netgear c6220 model for wifi. Now i switched to Spectrum that is the only internet available. Anyway i received modem ...
Apr 16, 2020Guru - Experienced User
The C6220 is a modem/router combo device. It doesn't have a wan port to connect the spectrum modem to so you can use it in router only mode.
You can't go spectrum modem------>modem/router combo device.
Potentially you can just run the C6220 on spectrum but its only approved up to 100mbps speeds and they'd need to provision it. have they done so?
