immortalsunset
Jul 08, 2022Aspirant
Netgear C6220 Wifi
I have had Netgear C6220 and my internet is Xfinity and it worked fine last 9 months. Since last two days I get NO INTERNET on all devices (Mobile Phone, Smart TV, Laptop) although I am connected to ...
Jul 09, 2022Guru - Experienced User
Got a screen snip of the cable connections page and the event logs?
Those help us check short term and longer term connection back to the isp.
- immortalsunsetJul 09, 2022Aspirant
Hi,
I attached the screenshot of Logs below.
Is there the problem with wifi channel or the hardware router problem?
I'd appreciate it if you please help me. It is very confusing and it's interesting after restarting the router I have stable internet connection and no disconnect until a few hours of inactivity.Thanks.
Logs
- plemansJul 09, 2022Guru - Experienced User
Look for the event logs. not just the logs.
Also the cable connections page.
Event logs is attached.
How to check the cable connections page? If you guide me I can send it now.
event Logs
