Augie74
Aug 27, 2024Aspirant
Netgear C6300 - AC1750 Cable Modem WiFi Router
Can I use the eithernet port on my netgear C 6300 cable modem/router to run a Google Nest Wifi Pro- Wifi 6E Home Wifi System? If so will I have all the functions of the Google Nest system that I woul...
- Sep 02, 2024
Thank you!!! It worked. I have connected a mesh network to my cable modem.
Aug 27, 2024Guru - Experienced User
Yes,
You could disable the wifi radios on the modem or put the modem into modem only mode then connect up your newer wifi router system:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
