dknaggert
Oct 20, 2016Aspirant
Netgear C6300 ambar upstream light.
Due to renovation I had to move the router. It is now on a splitter together with the TV. The the "Up Stream" LED stays solid amber. Internet doesn't work neither does my Vonage phone. This morning I...
DarrenM
Oct 28, 2016Sr. NETGEAR Moderator
Hello dknaggert
Yes you could be correct I would have comcast send someone out to check the signal on the new outlet.
DarrenM
Jody
Mar 10, 2017Apprentice
Charter out today. tested all cable....No noise on line... Since the cable was old I insisted we run new cable from road....New cable from road connection all way to router/moden... Didn't help crap...Has to be the Netgear.........Unreal they won't help...Guess my business will go elsewhere...Sad as i buy routers for business with over 100K employees.......Oh well their loss.........
- dknaggertMar 11, 2017Aspirant
In my case I found a solution to the problem. I checked by logging into 192.168.0.1 to find out which channels are crowded and switched to Channel 3 - every thing o.k. now
