cakesin
May 07, 2022Follower
Netgear c6300 no connection on ports 2, 3 and 4.
My c6300 doesn't connect devices to the internet or even show the slightest sign of working on ethernet ports 2, 3, and 4. Ethernet port 1 and the wi-fi works fine. There are zero signs of damage nor...
May 07, 2022Guru - Experienced User
Is the modem in router or bridge mode?
Try disconnecting the ISP coax cable from the modem and all wired devices to the modems ethernet ports.
Pull the power adapter from the wall out let for 30 seconds then plug back in. Connect 1 ethernet PC to one of the effected ports. Port 4. Wait for the modem to come to read. Does the wired PC get an IP address from the modem? Any LED indications on the modem for Port 4? Can you access the modems web page at all at 192.168.100.1?
Reconnect the ISP coax cable after checking the above items.
