cakesin
May 07, 2022Follower
Netgear c6300 no connection on ports 2, 3 and 4.
My c6300 doesn't connect devices to the internet or even show the slightest sign of working on ethernet ports 2, 3, and 4. Ethernet port 1 and the wi-fi works fine. There are zero signs of damage nor...
michaelkenward
May 08, 2022Guru - Experienced User
cakesin wrote:
Firmware version is V3.01.14.
I'm not really sure how to or if I can update.
You can't update the firmware on a cable modem/router.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
