BlueIron15
Aug 07, 2021Aspirant
Netgear C6300 Power light solid, Downstream light blinking and all other lights are off
I just ran into this problem and contacted Xfinity and they are sending out a technician. I am trying to understand if this is a problem with the modem or if it is a problem on xfinity's end. The co...
BlueIron15
The modem unable to lock in the downstream, is it a problem with the modem or with Xfinity?
I also tried what you suggested with no change happening.
Aug 08, 2021Guru - Experienced User
To little information to tell.
You can log into the C6300 and get a screen snip of the cable connections page and the event logs.
That can help.
