surround
Apr 05, 2016Star
Netgear C6300 wifi not working with samsung galaxy s7 edge and regular s7
I have s7 edge and regular s7. I have 200mbps with time warner and have the netgear c6300. It won't connect properly to app store, youtube, oculus store etc. The iphones in my house work perfectly, a...
- May 10, 2016Samsung recently released a software update and now I'm able to watch YouTube videos and update my apps on the Google play store. I got my phone from T-Mobile so idk if the other phone companies have released the update yet. I hope this is a permanent fix to the problems and not a temporary one like the fixes I found here. I don't have the money to buy another router and I've just been waiting for the WiFi problem to get fixed so I can use my phone at home.
Klt3505
Apr 06, 2016Star
I have the same issue and even got a replacement phone and it had the same issue. Can connect on public wifi, any other wifi, and twc with a different router, but not using netgear c6300. No other devices have an issue. I can surf the Web bUT can't use oculus or Google play.
- surroundApr 08, 2016Star
Yup, still having same problems, no google play store, oculus store etc. Are we going to get a solution?
- Klt3505Apr 08, 2016Star
I have contacted Samsung, TWC and Netgear with no luck. If I have to replace this router, that is not even 6 months old, I will replace it with another brand.
