surround
Apr 04, 2016Star
Netgear C6300 wifi not working with samsung galaxy s7 edge and regular s7
I have s7 edge and regular s7. I have 200mbps with time warner and have the netgear c6300. It won't connect properly to app store, youtube, oculus store etc. The iphones in my house work perfectly, a...
- May 09, 2016Samsung recently released a software update and now I'm able to watch YouTube videos and update my apps on the Google play store. I got my phone from T-Mobile so idk if the other phone companies have released the update yet. I hope this is a permanent fix to the problems and not a temporary one like the fixes I found here. I don't have the money to buy another router and I've just been waiting for the WiFi problem to get fixed so I can use my phone at home.
Klt3505
Apr 06, 2016Star
I have the same issue and even got a replacement phone and it had the same issue. Can connect on public wifi, any other wifi, and twc with a different router, but not using netgear c6300. No other devices have an issue. I can surf the Web bUT can't use oculus or Google play.
surround
Apr 07, 2016Star
Yup, still having same problems, no google play store, oculus store etc. Are we going to get a solution?
- Klt3505Apr 08, 2016Star
I have contacted Samsung, TWC and Netgear with no luck. If I have to replace this router, that is not even 6 months old, I will replace it with another brand.
