Mozes911
Mar 26, 2017Aspirant
Netgear C6300 wifi will not enable
I plugged everything in let everything lead up and called my internet provider to get access to internet. Once everything was arranged and a couple resets from the provider the wifi will not activate ...
Mozes911
I also cannot got to the netgear router sights while hardwored in either
William10a
Mar 26, 2017Master
Did you set the c6300 up as a router or gateway on page 12 of the users manual if the router question is selected as no the modem is now a gateway from saw in the manual?
Here is the llnk for the manual https://www.netgear.com/support/product/C6300.aspx#docs
