Mozes911
Mar 26, 2017Aspirant
Netgear C6300 wifi will not enable
I plugged everything in let everything lead up and called my internet provider to get access to internet. Once everything was arranged and a couple resets from the provider the wifi will not activate ...
michaelkenward
Mar 27, 2017Guru - Experienced User
The installation guide tells you the order that you need to follow to set up a new device:
>>>> C6300 | Product | Support | NETGEAR <<<<
Can you connect to the device as it shows in step 4 of that guide?
Can you connect to http://routerlogin.net or http://192.168.0.1?
