magicuno1980
Aug 30, 2018Follower
Netgear C6300 Wireless Gateway Firmware Update
My Netgear C6300 Wireless Gateway Modem is stuck on old firmware (version 2.01.08) and I can’t get an update from Comcast. They claim that they can’t do it, but Netgear says that I can’t manually upda...
vkdelta
Aug 31, 2018NETGEAR Employee Retired
are you on Comcast ISP? If yes, a reboot should upgrade the device.
If not, try factory reset.
Comcast pushes new FW upon bootup and sync to their network.
