TempTemp
Mar 25, 2019Follower
Netgear C6900 - Login does not work in Chrome - Your connection to this site is not private error
I wish to update my router settings. Tried logging in at http://routerlogin.net. Also tried the ip, http://routerlogin.com, http://www.routerlogin.net, http://www.routerlogin.com, I verified that my p...
michaelkenward
Mar 25, 2019Guru - Experienced User
Does this mean that your browsers block access, or that you are put off by those security warnings?
Is this a Windows warning?
By the way, it may not matter, but you have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's impenetrable community structure.) Your C6900 is a Cable Modem/Router.
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
