TempTemp
Mar 25, 2019Follower
Netgear C6900 - Login does not work in Chrome - Your connection to this site is not private error
I wish to update my router settings. Tried logging in at http://routerlogin.net. Also tried the ip, http://routerlogin.com, http://www.routerlogin.net, http://www.routerlogin.com, I verified that my p...
waterpn
Jun 20, 2019Aspirant
Thank you all for your help, but I give up. When I put in routerlogin.net it now asks for my user id and password. As soon as I do that I get an unauthorized message. Next time I need a new WiFi I will try another company, maybe one that just sends me an email that I can immediately connect with to update firmware.
Jun 20, 2019Guru - Experienced User
Be sure you are entering in the correct PW for the admin log in. If your not sure. Factory reset the modem and walk thru the setup wizard with a web browser and this time write down all important information. Its not that hard.
waterpn wrote:Thank you all for your help, but I give up. When I put in routerlogin.net it now asks for my user id and password. As soon as I do that I get an unauthorized message. Next time I need a new WiFi I will try another company, maybe one that just sends me an email that I can immediately connect with to update firmware.
- michaelkenwardJun 21, 2019Guru - Experienced User
It might also be worth pointing out that pretty well all router brands, and makers of many other things, have exactly the same routine for accessing the controls on their devices.
And as you point out, you have to get things right. If someone is entering the right details and it does not work, then look for the underlying problem.
Login failures are invariably down to getting the configuration wrong or to something else on the network getting in the way. Browsers are good at blocking access. Operating systems can do it to.
