xtamil2002
Jan 28, 2023Follower
Netgear C6900 as Router only
Hi Can the Netgear AC 1900 Wifi Cable Modem Router Model C6900 be used as a router - only. My current ISP insists on getting a modem from them. I want to know if i can use C6900 as the router alon...
Jan 29, 2023Guru - Experienced User
There's a work around to make it function as a type of access point (not router) by setting it with a static ip address and disabling dhcp on it. Again, it won't work as a router only
