bob7bob7
Jul 07, 2020Aspirant
netgear c7000 ac1900- lan port leds
should both green and amber led's be on when ethernet cable is pluged into one of the 4 lan ports on back of unit, and then pluged into computer. I only get the amber led. My speed seems to be about ...
antinode
Jul 07, 2020Guru
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
C7000 or C7000v2? Look for "Model" on the product label.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for the
LED descriptions and "Troubleshoot".
> [...] ethernet cable is pluged into one of the 4 lan ports on back of
> unit, and then pluged into computer. [...]
Try a different cable? Try a different port? "computer" is not a
very detailed description of that device. Is its Ethernet interface
gigabit-capable?
> [...] My speed seems to be about half what it should be.
What is your "My speed", measured how? What should it be?
bob7bob7
c7000, at work dont have unit with me
looked at manual, saw nothing about rear lan led's
test speed at isp website 50mbps wi-fi 72mbps ethernet . download speed
paying for 200mbps, dont know about computer having gig ethernet, but about 7 years old. HP desk top. Friends 2 year old lap top will do 100mbps on ethernet
