bdtice1's avatar
bdtice1
Netgear C7000 assigning wrong IP Address to new HP OfficeJet 8730 printer
I just got a new HP OfficeJet 8730 printer and can't get it to connect to the network.  I called HP and they looked at my router settings  and found that the router is assigning the incorrect IP addr...
  • TheEther's avatar
    Feb 18, 2017
    The router is not assigning 169.254.178.196 to the printer.  The printer is assigning that address to itself.  Most devices will self-assign an address in the 169.254.x.x range when they fail to obtain an address from a DHCP server.
    It sounds like your printer is old.  It may not support WPA2 security.  Log onto the router and switch the Wi-Fi security setting to either WPA or WPA+WPA2.
