bdtice1
Feb 17, 2017Aspirant
Netgear C7000 assigning wrong IP Address to new HP OfficeJet 8730 printer
I just got a new HP OfficeJet 8730 printer and can't get it to connect to the network. I called HP and they looked at my router settings and found that the router is assigning the incorrect IP addr...
- Feb 18, 2017
The router is not assigning 169.254.178.196 to the printer. The printer is assigning that address to itself. Most devices will self-assign an address in the 169.254.x.x range when they fail to obtain an address from a DHCP server.
It sounds like your printer is old. It may not support WPA2 security. Log onto the router and switch the Wi-Fi security setting to either WPA or WPA+WPA2.
TheEther
Feb 18, 2017Guru
bdtice1
Feb 18, 2017Aspirant
Thanks for your suggestion. The key was when you said it failed to obtain an address from the DHCP server. I turned off the router and printer. Turned the router back on after 1 minutes and let it start all the way. Then turned the printer on and this time I was able to connect to the network. Wish I would have thought about that earlier and saved hours of trying to figure out what was going on. Thanks again!
