Hypemudd
Mar 19, 2020Follower
Netgear c7000 becomes poor in signal once 10 devices are connected
Once my netgear has 10 devices connected, my WiFi drops. Please help, I am unsure if it is my router or my service provider (Comcast/Xfinity). Tried all the basic troubleshooting steps, but nothing works.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers - FURRYe38Guru - Experienced User
Are they all connected to 5Ghz or 2.4Ghz or are they spread out between the two frequencies? They should be spread out.
Try enabling any Beamforming and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes.
