lukeirves
Jul 02, 2018Aspirant
Netgear C7000 NightHawk stuck in Bridged passthrough mode and will not reset
I set the Cable modem to bridged/passthrough mode and have been using another router to connect to the wan. I want to change it back to working from the netgear again but i cannot get onto the cable ...
antinode
Jul 02, 2018Guru
> [...] i cannot get onto the cable modem as it is in passthrough. [...]
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
What are you using for a URL to access the modem+router? Have you
tried "192.168.100.1"?
> [...] I have tried facory reseting the unit 3 times with a paper clip
> and the unit does all the right things with its lights but nothing
> changes once i boots. [...]
I'd've expected that to work. Have you tried a reset with the
modem+router connected to nothing (other than its power adapter)?
