Brandonk42
Nov 12, 2019Aspirant
Netgear c7000 stuck in constant reboot cycle
Hi! I have a Nighthawk C7000. Our internet went out and so I thought I'd unplug it let it sit and plug it back in to see if that fixed the issue. Now the router seems to be caught in a reboot loop. Ev...
michaelkenward
Nov 13, 2019Guru - Experienced User
Brandonk42 wrote:
I've tried numerous things like changing the power adapter with the same voltage, switching plugs, etc.
Have you trieds a factory reset?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
By the way, it may not matter, but you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
- Brandonk42Nov 13, 2019AspirantI should have said that but yes I did tried to factory reset. It won’t do anything when I hold the reset button in. I tried the 30-30-30 method and it just won’t reset. It just keeps doing its cycle.
Thanks for the heads up on the post!- FURRYe38Nov 13, 2019Guru - Experienced User
I would make contact with NG support and ask if an RMA is possible for your modem.
Sounds like the modem is in a bad state and needs fixed or replaced.
