Brandonk42
Nov 12, 2019Aspirant
Netgear c7000 stuck in constant reboot cycle
Hi! I have a Nighthawk C7000. Our internet went out and so I thought I'd unplug it let it sit and plug it back in to see if that fixed the issue. Now the router seems to be caught in a reboot loop. Ev...
Brandonk42
Nov 13, 2019Aspirant
I should have said that but yes I did tried to factory reset. It won’t do anything when I hold the reset button in. I tried the 30-30-30 method and it just won’t reset. It just keeps doing its cycle.
Thanks for the heads up on the post!
Nov 13, 2019Guru - Experienced User
I would make contact with NG support and ask if an RMA is possible for your modem.
Sounds like the modem is in a bad state and needs fixed or replaced.
