corvairbob
Jan 16, 2020Tutor
Netgear C7000 V2 Nighthawk AC1900 Wifi Cable Modem Router
i have the c3700 combo unit and the last week or so i keep getting your connection is not private this site is not safe. i deleted norton security, deleted the chrome browser and put it back. i then r...
corvairbob
Jan 23, 2020Tutor
must be only the newer ones? i have 3 older units and none of them had this connection issues. so then if what you telling me is so, then most of the modems you see on ebay or amazon may be in the same boat. the isp may not connect them up if they do not want to. this guy almost did not want to but then he finally found that the modem i got was at one time on comcast and he cleared it for me to use.
i did have the comcast tech tell me they do not connect up there modems to other accounts unless the other owners are on the phone and consent to it. so there is something to that.
also because i have 5 mbps upstream that may be why only 1 channel connected up them. thanks
Jan 23, 2020Guru - Experienced User
Ya, if you had a 50Mbps upstream, then you'd see more channels being used.
Enjoy.
