hk85
Feb 05, 2016Aspirant
Netgear c7000 wont connect to my Avaya 9650 ip telephone
I have the netgear c7000 modem/router and have been working from home on vpn using this without any problems for a week. I have cable internet through time warner cable (earthlink high speed)The IT...
vkdelta
Feb 05, 2016NETGEAR Employee Retired
Hi,
interesting problem. I would like to work with you. I was not expecting as we have enabled IPSEC, PPTP, and L2TP pass through already in the Software.
There could be some issues with SIP ALG but looks like you might have already tried it.
do you mind doing a quick favor?
check what is the LAN IP for the Phone? Can you make it static IP on the Phone?
can you please port forward UDP/TCP 500, UDP/TCP 4500?
also add port 50 and 51 if it does not work?
Internet Protocol Security (IPSec) uses IP protocol 50 for Encapsulated Security Protocol (ESP), IP protocol 51 for Authentication Header (AH), and UDP port 500 for IKE Phase 1 negotiation and Phase 2 negotiations. UDP ports 500 and 4500 are used, if NAT-T is used for IKE Phase 1 negotiation and Phase 2 negotiations
Please PM if it works or it does not work.
hk885
Feb 06, 2016Aspirant
I'm not sure where I search for the LAN ID for the telephone. Can you tell me step by step how to find you the information and how to do the port forwarding? This is all new to me. Thanks in advance.
- hk885Feb 06, 2016Aspirant
Oh just FYI... i had to make a new username because i couldn't log in with the old one.
To be clear, the phone doesn't communicate with the router at all. When I go int the router settings and view the log there use no dhcp failure, nothing at all with the phone's mac address attached to it.
