rajredy7172012
May 23, 2020Aspirant
Netgear c7000
Hi! Im getting only 90 Mbps speeds on my Netgear C7000 modem and router. My internet service allows speeds upto 400 Mbps. Is there anyway I can get higher speeds? Thanks, Rajesh.
michaelkenward
May 24, 2020Guru - Experienced User
The C7000 is a modem/router?
Are you saying that you have a C7000 in front of another router?
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
"Stacked" routers can also cause the slowdown that you see.
- rajredy7172012May 24, 2020Aspirant
Yes, the C7000 is a modem and router combined in one device. I don't have any other router attached to it.
- michaelkenwardMay 24, 2020Guru - Experienced User
So where are you measuring this 90 Mbps?
Speedtest.net
