clifftoboggan
Aug 02, 2019Follower
Netgear C7000v2 All LAN Links down, only one can be active
Hi All So recently I ran into some issues with my C7000v2. Only one LAN Link (in the back of the router) can be active at a time. All cables will work, as I have tried several, but only one can b...
Aug 02, 2019Guru - Experienced User
Please post about this over in the cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Good Luck.
clifftoboggan wrote:Hi All
So recently I ran into some issues with my C7000v2. Only one LAN Link (in the back of the router) can be active at a time. All cables will work, as I have tried several, but only one can be used, which is the cable I am running via powerline adapter to my laptop. My Playstation 4 or Xbox One will not connect via Ethernet. On the Internet Port page in the Genie the image attached is what will show.
As an example, if a cable is run to my playstation, it will work, but another cable run at the same time to my PC will not work.
I have no idea what the issue is, I have power cycled, factory reset, run a cable loop that showed both lights on, everything I know to do. Any help?
- antinodeAug 02, 2019Guru
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Router Mode",
as in: ADVANCED > Administration > Router Mode.You want "Yes".
