EDRCOXAPPLE1
Sep 28, 2023Aspirant
Netgear C7000v2 and Apple
Hello, looking for help with this issue. New C7000v2 (Modem, WiFI, Router Combo). I have about 16 devices at home and they all work fine on Wired Network and WiFI, except for ANY Apple products ...
michaelkenward
Sep 29, 2023Guru - Experienced User
EDRCOXAPPLE1 wrote:
Why is Apple (Iphone and Ipad) so sensitive and can't connect to those specific web sites.
You'll have to ask Apple for answers to that question.
It has its own way of doing things.
You might like to read this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
EDRCOXAPPLE1
Sep 29, 2023Aspirant
Thanks for your input. Already tired all those scenarios and none address why specific websites are unreachable and other are reachable on Apple products at my home Netgear WiFi. Even tried LAN converter to Apple Plug to bypass WiFI and still have the same issues. Only with Apple products.
- michaelkenwardSep 30, 2023Guru - Experienced User
They may tell you to look at the router, when only Apple stuff breaks it does seem to point to something Apple at the core.
Another one that crops up here from time to time as the browsers people use. These are getting increasingly picky over security issues. For example, some fall over when you throw an "http" address at them. (They want to see "https".)
Do the logs on the C7000v2 offer any clues?
