nilsen9
Sep 09, 2023Follower
Netgear C7000v2 bridge mode - 1 active ethernet port
(EDIT - appears that it is common and normal for only one port to be active. This can be closed). I recently picked up an Eero mesh system and wanted to use my C7000v2 modem/router to just be a mod...
- Sep 09, 2023
I recently picked up an Eero mesh system and wanted to use my C7000v2 modem/router to just be a modem. As such, I put the gateway into “modem only” mode by turning the router portion off. However, I can only get one Ethernet port on the C7000v2 to work/be active. Since the Eero only has one extra port, I need the extra Ethernet ports on the modem. After turning off router mode does this really only have one active Ethernet port?As you have found out, in modem only mode only one Ethernet port is active on your C7000v2. This is normal operation for combination devices.
A four port unmanaged Ethernet switch is available for under $20 on Amazon. Make sure you connect it downstream from your router and not between your C7000v2 and the router.
You can mark your post as resolved so others may benefit.
Kitsap
Sep 09, 2023Master
