txt9900
Jul 21, 2024Tutor
Netgear c7000v2 cable modem/router no longer working with comcast
I have had my Netgear wifi cable modem router (c7000v2) for a little over two years on Comcast cable internet service. It suddenly stopped working, but the lights are all still on indicating it's wo...
- Jul 24, 2024
I performed the hard reset. Re-configured the cable/modem router. After re-provisioning it with Comcast, it now works fine. Back up and running.
Thanks.
Jul 21, 2024Guru - Experienced User
They do last longer than 2 years. My in-laws are using my old C7000 from almost a decade ago.
do you have a screensnip of the cable connections page and event logs? That helps to check the connection
- txt9900Jul 22, 2024Tutor
Unfortunately, I don't have screenshots. I work from home and tried re-booting the cable modem/router but that did not solve the issue.
Then I had to resort to my old Linksys CM-3016 modem and an old Netgear N300 router. Comcast had no issue provisioning the Linksys cable modem and get me working. So, it's not my cable connection.
I did some research later and then saw you can do a hard reset of the Netgear AC1900 unit. Then I did the hard rest with a pin.
But I have to call comcast and see if they can re-provision the Netgear AC1900 again, to see if the hard reset solves the issue.
- FURRYe38Jul 22, 2024Guru - Experienced User
Please post a copy and paste of the C70000 modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- txt9900Jul 24, 2024Tutor
Thanks.
