txt9900
Jul 21, 2024Tutor
Netgear c7000v2 cable modem/router no longer working with comcast
I have had my Netgear wifi cable modem router (c7000v2) for a little over two years on Comcast cable internet service. It suddenly stopped working, but the lights are all still on indicating it's wo...
- Jul 24, 2024
I performed the hard reset. Re-configured the cable/modem router. After re-provisioning it with Comcast, it now works fine. Back up and running.
Thanks.
Jul 28, 2024Guru - Experienced User
Thats the value for most ISP and ethernet connected devices. Yes this is default. Would not effect wireless.
Most Cable and Fiber ISP services use default 1500. Older DSL ISP services used 1472 or other values less than 1500.
txt9900
Jul 28, 2024Tutor
ok thanks. One of these days, when I have some time, I'll try to disable the security on wifi and see if that help connect. In the meantime I am up and running on my old linksys CM-3016 cable modem with Netgear N300 router,
