emitova's avatar
emitova
Netgear C7000v2 Firmware V.1.03.03 2.4G wifi problem
I have AC1900 C7000V2 Modem Router connected to Xfinity. The firmware is V.1.03.03. About a month ago, the 2.4Ghz-wifi connection started being unstable while the 5GHz is working fine. Most of the t...
  • FURRYe38's avatar
    Feb 03, 2022
    Has a factory reset and setup from scratch been performed?
    Power OFF the modem fully for 1 minute then back ON?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz.
