sekhanh
Jan 30, 2021Follower
Netgear C7000v2 Firmware V.1.03.03 5G wifi problem
I have AC1900 C7000V2 Modem Router connected to Xfinity. The firmware is V.1.03.03. Just recently (less than a month), the 5Ghz-wifi connection is unstable while the 2.4GHz is working fine. Most o...
robertt202
Aug 06, 2021Aspirant
Same problem for me on the Cox network.
come on Netgear - get it together
- FURRYe38Aug 06, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed?
