marunakumar
Nov 15, 2022Aspirant
Netgear C7000v2 is not connecting to internet
Hi All, I have C7000V2 and it stopped working for the past 2 days. I see my network name on all the devices but cannot connect to internet. The xfinity technician told me that there is no problem wi...
Nov 16, 2022Guru - Experienced User
Do you have a screensnip of the cable connections page and event logs?
Those help us check the lines and xfinity's first reponse is always "its not the line"
- marunakumarNov 16, 2022Aspirant
Thanks for the quick response.
Here are the screenshots.
I have restarted it several times and even reset it. When Xfinity technician used his own modem, it worked without any issue and hence he felt that the issue was with the modem.
Thanks again.
How do I get the event logs though?
Aruna- FURRYe38Nov 16, 2022Guru - Experienced User
