rohitruls
Oct 26, 2021Aspirant
Netgear C7000v2 Modem Router - Slow Internet speed over 5GHz wifi network
Hi All, I have a 600mbps Internet only plan from Xfinity/Comcast. I purchased a Netgear C7000v2 Modem Router (AC1900) to replace my old router + modem setup. The New Netgear C7000v2 Modem Rout...
Oct 26, 2021Guru - Experienced User
What wireless devices are you using to speed test with?
What connection rates are you seeing with these devices connected to the 5Ghz radio?
Depending upon devices and connection rates, most devices max out at around 300-500Mpbs depending upon there support and design. Not all wifi devices can speed test beyond these speeds on 5Ghz. 1x1 or 2x2 antenna supporting devices is a factor. 4x4 devices can support higher speeds.
