helphelpplz
Jul 29, 2020Follower
Netgear c7000v2 Port forwading from home to Hikvision Camera at Work?
AC1900 Wifi Cable Modem Router Model c7000v2 I have hikvision cameras at work and I'm trying to set up remove viewing from home. I was told I need to port forward ports 80, 8000 and 105554 to th...
vkdelta
Jul 30, 2020NETGEAR Employee Retired
Internal IP address is the IP address of the Camera.
Dont forward the whole range. Just specific ports needed. this is for security reason.
External IP address is your WAN/Internet IP address. It should be autopopulated.
antinode
Jul 30, 2020Guru
> autopopulated.
The (not-too-clear) User Manual (page 101) says:
13. In the External IP address menu, select one of the following
options:
o Any. This options [sic] is selected by default.
o Single address. Enter the external IP address.
I see nothing like it on my D7000[v1] (V1.0.1.78_1.0.1), so I know
nothing, but I read that as access control affecting the external
client, not anything to do with any address on the modem+router.
So far as I can tell, the User Manual doesn't say whose IP address that
might be.
