AstralSayian
May 05, 2023Aspirant
Netgear C7000V2 recently started disconnecting randomly.
Recently my device has been dropping connection for some reason and I am not sure why. My ISP is RCN and we have contacted them about it. Netgear says that the newest Firmware for this device should ...
AstralSayian
May 06, 2023Aspirant
So exactly what would it be on the ISP end that they need to fix?
May 07, 2023Guru - Experienced User
Ask the ISP that.
Info has been posted as well. Have this review this.
- AstralSayianMay 07, 2023Aspirant
So I called my ISP and told them everything. They said everything looks fine on there end and that they don't see any issues. Could it be the router itself? Is there a way to manually update the Firmware? The ISP says they cant update that.
- FURRYe38May 08, 2023Guru - Experienced User
Issue is on there side. Line issues are being reported by the modem in the event log.
Try a different modem and see.
ISPs can only update FW on C and CM series modems.
