timmyK
Dec 03, 2021Aspirant
NETGEAR c7000v2 slow speed with blinking lights
I have 200 Mbps connection and I get around 120-180 Mbps during the day. At nights, it gets slow. (20-40 Mbps). These lights are blinking a green light on the router: Download arrow 2.4GHz ic...
Dec 04, 2021Guru - Experienced User
Are you using an amplifier? Based off the power levels that you have for your downstream, your upstream is pretty high.
If you have any amplifiers, splitters, or signal attenuators in the line, remove them.
do you also have the modem event logs? That helps us check long term.
All rebooting does is clear out the errors. It might help the speeds short term if the modem connects on a different frequency but long term, it isn't going to fix the problem.
timmyK
Dec 06, 2021Aspirant
plemans Thanks for the reply. I don't have any amplifier setup. I hooked up the ISP cable directly into my router
Connection seems to be stable now, but the lights on the router are still blinking. (downstream arrow, 2.4ghz, 5 ghz icons).
Attaching the event logs:(Advanced > Administration > Event Logs)
| Time | Priority | Description |
| 2021-12-3, 22:13:04 | Warning (5) | MDD message timeout;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:45 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl0] set to Channel 2 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2021-11-24, 12:22:52 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0; |
| 2021-11-15, 12:35:58 | Critical (3) | SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2021-11-8, 22:48:10 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.1;CM-VER=3.0; |
| 1970-1-1, 00:39:09 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:39:03 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:58 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:56 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:55 | Critical (3) | DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:07 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:06 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:38:03 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:37:24 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:37:22 | Critical (3) | DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:36:35 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:36:31 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:36:29 | Critical (3) | No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:36:12 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:36:11 | Critical (3) | No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:35:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:35:53 | Critical (3) | No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:35:29 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:35:28 | Critical (3) | DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:41 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:40 | Critical (3) | No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:23 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:22 | Critical (3) | No UCDs Received - Timeout;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:05 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:04 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:03 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:34:01 | Critical (3) | DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:33:14 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:33:08 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:33:08 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:33:06 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:4d:0b:98;CMTS-MAC=00:01:5c:65:0e:72;CM-QOS=1.0;CM-VER=3.0; |
And here is the logs (Advanced > Administration > Logs)
I was very concerned about DoS attack at first, but then read online that it's a false alarm due to iPhone or iPad devices.
| admin login failure] from source 192.168.0.21 | 1 | Mon Dec 06 13:01:03 2021 | 0.0.0.0:0 | 192.168.0.21:0 |
| [DoS attack: Ping Of Death] from 73.1.0.80, port 0 | 3 | Mon Dec 06 12:49:22 2021 | 232.215.176.155:0 | 73.1.0.80:0 |
| [DoS attack: Teardrop or derivative] from 73.1.0.80, port 0 | 1 | Mon Dec 06 12:49:20 2021 | 232.215.176.155:0 | 73.1.0.80:0 |
| [DoS attack: Ping Of Death] from 73.1.0.80, port 0 | 2 | Mon Dec 06 12:48:36 2021 | 232.215.176.155:0 | 73.1.0.80:0 |
| [DoS attack: Teardrop or derivative] from 73.1.0.80, port 0 | 2 | Mon Dec 06 12:48:35 2021 | 232.215.176.155:0 | 73.1.0.80:0 |
| [DoS attack: Ping Of Death] from 73.1.0.80, port 0 | 8 | Mon Dec 06 12:46:33 2021 | 232.215.176.155:0 | 73.1.0.80:0 |
- plemansDec 06, 2021Guru - Experienced User
The 2.4ghz/5ghz lights will blink. That just indicates data transfer.
the downstream icon should be locked.
You are having error and not locked channels.
And while your power is technically in spec, somethings causing issues. That can be told by how high your upstream power levels are in relation to your downstream. Add in the errors and not locked channels and I'd be checking the cable/wires/connectors.
If that doesn't help, then the ISP would need to check the line.
