MartyGraw
Feb 21, 2022Initiate
Netgear C7000v2 Slow wifi speed
I recently upgtaded my broadband plan (Breezeline formerly Atlantic Broadband) from 100mbs down 5mbs up to a blazing 600mbs down and 50mbs up. I am seeing those speeds on my wired connections. Unfort...
MartyGraw
Feb 22, 2022Initiate
I did a factory reset on the modem.I was testing at 2.4G. I just tested at 5G next to the modem and I got 328mbs download and 50mbs upload. thanks for your help!
Feb 22, 2022Guru - Experienced User
glad it was an issue of the band connected to!
If you mark it solved, it might helps others with the issue and prevents others from trying to fix it as well :)
