DanielGGV
Dec 07, 2022Tutor
NETGEAR C7000v2 using as bridge mode
Dear all, I have read a lot on this forum about the subject that I'm going to describe, but I've not found a solution to my problem. I have a NETGEAR C7000v2 modem/router/wifi and I want to connect a...
- Dec 08, 2022
Try this, set the C series modem for modem only mode then connect 1 wired PC to the back of the modems LAN ports, Try LAN #1 port. After the mode reboots, check with the PC...does the PC get internet services here at all?
