Trunk_Monkey
Jan 14, 2022Follower
Netgear c7000v2 with external router
Hello! I upgraded my internet plan from Xfinity a few months ago and have gone over my monthly limit every month since. I wanted to monitor bandwidth usage by device to see what the culprit was, bu...
Jan 15, 2022Guru - Experienced User
when you turn on modem only mode, it literally becomse just a modem.
Meaning the isp needs to reassign the public IP address it assigns.
So when you switch the netgear to modem only mode, it needs to be powered off and rebooted in the proper sequence to reassign that ip address.. Make sure everything is disconnected from it and power it off.
Then wait 2 minutes. (have the asus off and starting from factory too)
Power the netgear back on and give it a couple minutes to fully boot.
then connect lan port 1 to the asus's wan port.
boot up the asus and wait a couple minutes.
Attempt setup on the asus.
