Melvinejr
Apr 09, 2020Tutor
Netgear c7000v2
My cable modem/router is connected to my smart tv and last night I just couldn’t watch TV anymore. I reset the modem by unplugging the power and Ethernet cables. It doesn’t connect to the internet but...
Apr 10, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Melvinejr
Apr 10, 2020Tutor
Thanks! The ISP is coming tomorrow
- FURRYe38Apr 10, 2020Guru - Experienced User
:smileywink:
- MelvinejrApr 11, 2020TutorOk, the ISP came and it’s working. Last night I noticed that the light for my 5 G band no longer shows up only the 2.4. How do I fix that?
- FURRYe38Apr 11, 2020Guru - Experienced User
Does rebooting the modem help?
Log into the modems web page and make sure the 5Ghz radio is enabled and working. Review the user manual.
