dan305
Mar 07, 2022Tutor
netgear c7000v2
Hello i have the netgear c7000v2 and i used to have 400 mbps and before i would get all my speed. Xfinity upgraded to 600 mbps but after that im only getting 275. I have tried everything on the setti...
Mar 07, 2022Guru - Experienced User
What wired speed do you get from a hardwired pc/laptop?
the in app netgear speedtest isn't accurate.
And that router is a combo device. I've never seen it hit 400mbps over 5ghz. 300mbps is more what I've seen.
And I'd normally tell you to post in the proper forum but it'd be me responding over there.
I'll see if I can get a mod to move it.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
dan305
Mar 07, 2022Tutor
i can tell you that in the xfinity modem i saw 580 and even 600. On this modem when i used to have the 400mbps i would see like 380 and more it was very close to the 400 i saw it myself. I test my speeds on wireless 5ghz all the time my computer is old and wont get those speeds.
