dan305
Mar 07, 2022Tutor
netgear c7000v2
Hello i have the netgear c7000v2 and i used to have 400 mbps and before i would get all my speed. Xfinity upgraded to 600 mbps but after that im only getting 275. I have tried everything on the setti...
Mar 07, 2022Guru - Experienced User
How were you testing the speeds before?
With the built in test?
And is that the same with the xfinity (has its own built in speedtest)?
If so, those tests are hosted on the router. Not on the device you're testing on.
And the netgear one is notorious for choosing the wrong server.
Its again why we recommend testing wired.
dan305
Mar 08, 2022Tutor
ive looked at the distance and before the update i would use the same websites xfinity and speedtest so i know they are the same.
- dan305Mar 08, 2022Tutor
do you need a docis 3.1 and wifi 6 to get 600 mbps from xfinity maybe its that. I just dont understand why that doesnt work
- FURRYe38Mar 08, 2022Guru - Experienced User
Something to ask the ISP about for sure, however:
https://www.netgear.com/images/datasheet/networking/CableModems/C7000.pdf
"Certified with Xfinity with speeds up to 600Mbps, Spectrum service of 400Mbps, and with Cox service speeds of 150Mbps"
ive spoken to xfinity a bunch of times they just send firmware and it stays the same they really dont know.
