dan305
Mar 07, 2022Tutor
netgear c7000v2
Hello i have the netgear c7000v2 and i used to have 400 mbps and before i would get all my speed. Xfinity upgraded to 600 mbps but after that im only getting 275. I have tried everything on the setti...
dan305
Mar 08, 2022Tutor
ive looked at the distance and before the update i would use the same websites xfinity and speedtest so i know they are the same.
dan305
Mar 08, 2022Tutor
do you need a docis 3.1 and wifi 6 to get 600 mbps from xfinity maybe its that. I just dont understand why that doesnt work
- FURRYe38Mar 08, 2022Guru - Experienced User
Something to ask the ISP about for sure, however:
https://www.netgear.com/images/datasheet/networking/CableModems/C7000.pdf
"Certified with Xfinity with speeds up to 600Mbps, Spectrum service of 400Mbps, and with Cox service speeds of 150Mbps"
- dan305Mar 08, 2022Tutor
ive spoken to xfinity a bunch of times they just send firmware and it stays the same they really dont know.
